t500 engine cases
- stevebee
- Country: australia
- Suzuki 2-Strokes: t500 kawasaki z900 harley davidson flsti
t500 engine cases
Can anyone tell me if I can put crank and gears from a 1971 engine into 1976 cases
- ConnerVT
- Novice racer
Re: t500 engine cases
1971 = T500 with point ignition.
1976 = GT500 with CDI
Crankshafts are different, have a different end on the crank on the ignition/alternator side.
- stevebee
Will the 1971 crank fit if I stay with pointsConnerVT wrote:1971 = T500 with point ignition.
- Jimroid
Cranks interchange.You just need to use points ignition with pre-76 crank.
- stevebee
ThanksJimroid wrote:Cranks interchange.You just need to use points ignition with pre-76 crank.
You should consider doing the transmission mod. Its in this service bulletin:
http://www.ozebook.com/compendium/techb ... %201-5.pdf
- Country: canada
- Suzuki 2-Strokes: gt 500 x2
Crank and gears will interchange but the stator plate for electronic ignition sits a little further out. You can shim out the
three bosses on the casing to properly locate the electronic (GT) plate.
Buy the way PaulMiller has two cases on Ebay that come from me serials 68567 and 43852 that I consider were not paid for.
He also stole a GT crank from me and does not reply phone or Emails. You will also be seeing 12 mufflers, 8 carburetors, gas tanks, wheels
and a whole pile of other stuff that were not compensated for.
Warren
Warren
- stevebee
Thanks for the information . I have never had any dealings with Paul Miller I hope it works out for youbugspray wrote:Crank and gears will interchange but the stator plate for electronic ignition sits a little further out. You can shim out the
Warren
