Mikuni Oil Pump
Posted: Sun Jun 11, 2017 9:42 pm
by TIKI
I want to go through the Mikuni oil pump on a 1971 TM400R, any suggestions on where to find the O-rings and seals for the pump?
Re: Mikuni Oil Pump
Posted: Mon Jun 12, 2017 7:12 am
We did this a while back for the T250/GT250/T350/T500/GT500 oil pumps. Most of the o-rings & seals were pretty common & easy to get. But one wasn’t easy to find.
The screw on the T250… pump, which is used to prime the pump, has left-hand threads because of the pump’s rotation direction. So be careful with the screw on your pump that is facing the camera in your pic — it may have either right-, or left-, hand threads.
Good place for o-rings:
http://www.theoringstore.com
I would have to lookup the sources for seals. So if you have troubles finding the seals, let us know & post the sizes.
Re: Mikuni Oil Pump
Posted: Mon Jun 12, 2017 3:17 pm
by TIKI
Thanks jabcb, I ended up doing a little research and found all but one O-ring available on Partzilla through Kawasaki the pump looks identical to mine. I placed the order and hope it’s all correct when it arrives.
