Master cylinder rebuild
Posted: Mon Jan 29, 2018 2:46 pm
Hi Guys ,
I decided to powder coat my front brake caliper and master cylinder over the winter . ( GT550 m )
I ordered what I thought was the correct parts , however when they arrived they did'nt match what I had taken out !!
I was then advised that some kind person had replaced my master cylinder with a GT250 unit .
can someone please advise if I have the parts in the correct order to be fitted as I cannot find any info on line .
First in is spring open end , black rubber clips into small end of spring , then small thins brass disc , followed by ali piston c/w rubber seal , then all held in place by a circlip then fit rubber boot ???
Thank you
( damned photos won't upload !
Thank you
