GT185 Brake light switch spring fitment ??
Posted: Mon Sep 17, 2018 9:38 am
Recently bought a semi dismantled 1977 gt185 & one stupidly minor thing that's driving me nuts because I can't figure it out is WHERE does the brake light switch spring fit onto ??
There is a small drilled hole in the back of the pedal at about the correct length but hooked into here the spring rubs on the frame - ???
There is also a hook welded onto the pedal but is way too far away for the spring to reach ? Also, if not for the spring what the hell os the hook for ??
