GT250M & RL250 carb o-ring
Posted: Mon Aug 26, 2019 9:17 am
The o-ring between carb & carb insulator, part # 13295-97700, is NLA & none are listed on eBay.
(The GT250J/K have a slightly different carb & the o-ring part number is different.)
Anyone know a superseding part number or the o-ring dimensions?
Should be able to get one at this retailer, but what material should be used?
https://www.theoringstore.com/store/ind ... &cPath=368
Re: GT250M & RL250 carb o-ring
Posted: Mon Aug 26, 2019 3:36 pm
by sportston
Ask Dollydog? I'd be surprised if he doesn't know. He seems to know everything there is to know about the GT250
by sportston
Posted: Tue Aug 27, 2019 1:04 am
You can even ask him twice, but you'll only get one answer!! :wink:
Posted: Tue Aug 27, 2019 6:50 am
Suzuki GS-series bikes use o-rings between the cylinder head & carb holders. That’s a similar need, so I asked about it on that forum.
Viton was recommended.
https://www.theoringstore.com/store/ind ... ath=368_65
Now to figure out the correct size.
Posted: Tue Aug 27, 2019 2:07 pm
by sportston
Alan H wrote:You can even ask him twice, but you'll only get one answer!! :wink:
No idea why it did that. I only posted it once. :wth:
Posted: Tue Aug 27, 2019 2:27 pm
Must be a glitch in the matrix. :wink:
Posted: Tue Aug 27, 2019 2:56 pm
by sportston
Perhaps I took the wrong pill yesterday morning. I always get red and blue mixed up.
Posted: Tue Aug 27, 2019 3:33 pm
sportston wrote:Perhaps I took the wrong pill yesterday morning. I always get red and blue mixed up.
Most likely the internet+browser was acting a little slower than typical for you, and you hit “submit” a second time before getting a response.
Posted: Tue Aug 27, 2019 4:46 pm
Turns out I have a few different o-rings in my spare parts collection.
13295-97700 is 3.0mm dia x 38.5mm OD (hand written part # by seller)
13295-18011 is 3.0mm dia x 43mm OD (measured about 3.05mm dia) (hand written part # by seller)
09280-32001 is 3.5mm dia x 38.7mm OD ==> 31.7mm ID (purchased from Suzuki dealer using part #)
Posted: Wed Aug 28, 2019 1:12 am
Your finger has a stutter?
Posted: Wed Aug 28, 2019 11:55 am
by dollydog
pm sent. pm sent :D it was this morning, so perhaps the u.s.a. isn't awake yet?
Posted: Wed Aug 28, 2019 12:51 pm
by sportston
No it d d doesn't! My computer had the hiccups.
Posted: Wed Aug 28, 2019 1:23 pm
Posted: Fri Aug 30, 2019 9:07 am
Got some NOS o-rings:
13295-18620 is 3.5mm dia x 39.7mm OD (with Suzuki part # label)
So the GT250K/L o-rings (13295-18620) & the GT250M o-rings (13295-97700) have different thicknesses (3.5 vs 3.0) but essentially the same IDs (32.7 vs 32.5).
Fortunately there is no need to try to reuse your old o-rings because they are NLA, or search for NOS o-rings, because they are available in viton at TheOringStore.com & elsewhere.
