Oil Tank Outlet Assembly Gaskets
- Suzuki 2-Strokes: 1966 T20
Hi to everyone I need some help. Does anyone have a source or solution for the two rubber gaskets in the oil tank outlet assembly? It is the assembly that screws into the bottom of the oil tank where the outlet oil line goes to the oil pump Any help would be appreciated.
Re: Oil Tank Outlet Assembly Gaskets
Hi,
The two gaskets are still available from Suzuki.
GASKET (44733-11030)
GASKET (44346-05110)
Cheers Geoff
Cheers Geoff
Geoff,
Thanks for the reply. The little gasket part number for my T20 is the same as yours (44733-11030), but the big gasket part number is 44346-02030. You gave me the number 44346-05110. Is this an updated part number. Will I need a year/bike model number to reference when ordering with these part numbers, or just give the parts guy the numbers and he can order them as I doubt they are in stock. Thanks for any and all help
ettore
ettore
44346-02030 is also used on the T500. Partzilla shows that the gasket was superseded by 44346-05110.
https://www.partzilla.com/catalog/suzuk ... e-oil-tank
Thanks guys everyone has been most helpful.
ettore
ettore
