Spoke Question
Posted: Tue Jun 22, 2010 2:35 pm
Pardon the bad pun, but a lot is riding on this
I picked up a set of spokes from this fellow on eBay for my '73 Buffalo as I had dealt with him before and he had a good feedback score. However when I compare the originals to the new ones they are different. The new ones are made of an odd size wire of just under 9 ga (so a diameter of 3.45 to 3.48 mm) and not swedged at the hub end. The originals are thinner at the rim end (10 ga wire or 3.2 mm) and swedged out to a thicker 8 ga (or 4mm) at the hub end. Although the overall thicker diameter wire seems like a good idea, the fit just seems a bit too sloppy at the hub end.
So the question - has anyone else used these same spokes on a Buff ? And if so, are you happy with the fit ? My inclination is to bin them and either get a set of Suzuki ones or go to someone like Buchanans, but I thought I'd get some input first. Thanks in advance.
