Solving my T500 running issues
Posted: Thu Jul 08, 2010 11:06 am
As some of you may have read in my trip post:
http://www.motorcycleracer.net/phpBB2/v ... php?t=3019
My 1969 T-500-II made it the first 160 miles with no problems. Then in 100 degree heat and a dirt/gravel uphill section, I lost all power. For the rest of the trip the engine seemed to run well for the first 10-30 miles then it would starting pinging and having trouble with the right cylinder.
Battery read 12.8v when off, and still reads 12.8v. I'll check it again while running, but I do not believe that low battery was the issue.
I am a bit suspect of the plug caps. I replaced the left one on the road, which appeared a tiny bit loose, and will replace the right cap, but this wouldn't explain why it only happens after 10-30 miles.
Timing appeared a bit off and we retimed the bike in a gas station parking lot with a timing gun, after which it was much more responsive than it had been on the entire ride. The 10-30 mile pinging issue persisted. Timing was checked again but was spot on according to the timing gun. I am thinking that this is the highest probable issue, and that the bike MUST be retimed with a dial indicator. This is my first priority.
However, I have recently read some scathing reports about SIMILAR issues to what is happening to my Titan due to KEYSTER Carb kits. Roughly 1000 miles before the trip I rebuilt both my carbs with Keyster kits, so I am extremely concerned by this. The root of the issue seems to be the needles themselves? Evidently, due to the fact that the Keyster kit supplies needles in a different material that the original, it screws up the carb operation? I read a report that one individual had to place the clips on the lowest setting in order to get proper operation.
So, does anyone have any insight into the carb kit issue? Anyone else have issue with the keyster kits, specifically the needles?
It might be a non-issue after I do the dial timing...
