T350 crankshaft
T350 crankshaft
I need to put crank seals in my T350R. My question is, is the center crankshaft bearing supposed to slide side to side on the crank? If not, will the crank from a T250II fit? I've been looking and haven't found a parts list for the 250 to see if the part numbers are the same. Everyone has listings for earlier and later models, but none for the 250II. thanks
Re: T350 crankshaft
Not a crank expert so I can't help you on the tech question.
The T350 & T250 use the same crank -- they have the same part numbers.
Online parts manuals can be a little quirky. All the T250s are listed under 1972.
1971 T350R crank:
http://www.suzukipartshouse.com/home.as ... 6091310004
crank assembly part # 12000-18802
1971 T250R & 1972 T250J:
http://www.suzukipartshouse.com/home.as ... 0912900B06
1970 T250II crank:
1971 T350R crank:
1970 T250II crank:
