1972 gt750 muffler cone removal
Posted: Mon Sep 23, 2013 2:46 pm
by kiwi
hi guys,can anybody tell me how to remove the muffler cones from exhaust on 72 gt750,they seem pretty solid and cant find a screw or anything,do you just tap them out,any help appreciated
Re: 1972 gt750 muffler cone removal
Posted: Wed Sep 25, 2013 6:11 pm
by oldjapanesebikes
They are a twist and lock design and there should be a retainer bolt - after removing that bolt (on the underside) if you push on the end of the cone and at the same time give them a twist (I forget which way, but try going left and see what happens) they should eventually come off. A hot air gun may speed up the process, but try not to damage the rubber seal.
Posted: Thu Jul 30, 2020 12:50 pm
by artsmokes
Just had mine off of my 72 GT750J Just loosen the Phillips screw through the hole in the cone and twist counterclockwise. Take the screw out to remove baffle
