1969 T305 Raider
- Country: usa
- Suzuki 2-Strokes: 1969 Suzuki T305
1969 T305 Raider
Hello
I've bought a rough, barn find 1969 T305 Raider. Although it kind of rolls, It needs basically everything. I'd like to start assembling a pile of parts and do a restoration next Winter when the snow falls.
I'm wondering, when I am searching eBay and the like for parts, will parts from say a 1968 T305 or Hustler or any of that vein work on my bike? Which other models does the '69 Raider share parts with?
Thanks in advance.
Thanks in advance.
Re: 1969 T305 Raider
The T305, T250 & T350 share a lot of parts.
Use an online part ordering system to lookup the part number, then use the part number to find what other bikes have the part.
Some Suzuki dealers provide good discounts via their online parts ordering system.
Dillons is one of the ones I use: http://www.buymotorcycleparts.com/suzuki_parts.htm
You might find a printed parts manual useful. Several are available via eBay.
Keep in mind that NOS parts on eBay are often more expensive than the Suzuki dealers that discount.
Have fun with you project.
- T350guy
- Suzuki 2-Strokes: 1977 GT 750
What I found when gathering all the required parts for our 69 T350 is the difficulty in finding them .In 70 everything became more common and easily obtained From switches to speedo & tachs.
Be patient as the parts will pop up once in awhile at a good price.
Last fall we managed to get a almost new speedo for less than $40 and a NOS Tach for $50.Cables are available as are piston/rings at CHEAP prices..$24 for 2 NEW Std pistons and about the same for rings.
I thought the T305 was only made for 1968. Trivial point.
Take carbs off and see if water damage. There is one extra pilot jet: first one you see with bowl off right at surface of carb body. That is obsolete (not sure how important it is…). If not much water damage you may want to soak that one a while to loosen a bit. You can get everything else new (Needle Jet, main jet, pilot…. If Jet needle for some reason bad, I think the Keyster kit for T350 is for the early one and the same jet needle. Keyster float valve OK and works on T305 (please verify.. been a while). Keyster Bowl gasket OK. Would not use anything else but pure Mikuni for all other jets. Crusinimage on ebay T350 kit is complete junk.
Pop head off at least and see what size pistons. There was a good lot of t305 piston std, 0.5 and 1.0 on eBay low price compared to T350.
The head gasket from T350 works. Be carful the one for t250 will not even if they say it does fit ...Smaller bore.
All other engine parts same as T350/GT250 (early). Crank, etc. Oil pump has different rate but same gasket kit as T500 if you need (look on eBay... someone on this post did all the leg work for it).
Oh, for a 305 its fast.
73 Kawasaki H1 500
73 Kawasaki H1 500
- Country: Australia
- Suzuki 2-Strokes: Suzuki t500 69,71,73, Gt500 76
The t305 was made in 68 and 69.
1969 T500
1973 T500
1971 T500 (being restored)
1976 GT500 (being restored)
2012 Ninja 650
1973 T500
2012 Ninja 650
Was it made for 1968 model year but sold in 1968 and 1969 some countries. I mean did antyhing change between years or just carried over?
http://en.wikipedia.org/wiki/Suzuki_T_series" onclick="window.open(this.href);return false;
says "T305 Raider (only actually produced for about one year ca. 1968)"
NADA only shows it in 1968 USA
http://www.nadaguides.com/Motorcycles/1969/Suzuki" onclick="window.open(this.href);return false;
http://www.nadaguides.com/Motorcycles/1968/Suzuki" onclick="window.open(this.href);return false;
73 Kawasaki H1 500
73 Kawasaki H1 500
Looks like Suzuki sold the T305 as a 1969 model.
From eBay manuals & literature:
official printed parts manual for 1969 T305
http://www.ebay.com/itm/SUZUKI-1969-T30 ... 1027348466
official microfiche parts manual for 1969 T305
http://www.ebay.com/itm/Suzuki-T305-TC3 ... 0895511945
- Country: Ontario, Canada
- Suzuki 2-Strokes: B100P,T200, 68,70,74 T500,GS650G DL1000
I did briefly own a 68 T305 Raider last year, it was a 68 and titled as a 68. The 68 had the chrome tank panels, rubber knee inserts, suede seat with buttons, and the engine cases were painted silver. I would post a picture but this is all I get:
Sorry, the board attachment quota has been reached.
68 B100P x2
68 T500 Cobra x3
69 T500
70 T500 x2
74 T500
76 GT185 x2
81 GS650G x2
04 DL1000
68 T500 Cobra x3
69 T500
70 T500 x2
74 T500
76 GT185 x2
81 GS650G x2
04 DL1000
The T305 was produced up to the first half of 1969 until the T350 came out.
1969 T500
1973 T500
2012 Ninja 650
1973 T500
2012 Ninja 650
So point being only one model ever made that carried over into 69 if I understand.
73 Kawasaki H1 500
73 Kawasaki H1 500
Looks like that's the case
1969 T500
1973 T500
2012 Ninja 650
1973 T500
2012 Ninja 650
- Suzuki 2-Strokes: TC200, T20, T305, TC305, T500, GT 380
Here's mine.... original and un-restored.
http://www.vjmog.com/modules.php?set_al ... _photo.php" onclick="window.open(this.href);return false;
http://www.vjmog.com/modules.php?full=1 ... _photo.php" onclick="window.open(this.href);return false;
Ivan
Ivan
http://www.ivansperformanceproducts.com" onclick="window.open(this.href);return false;
Ivan,
That is gob smacking beautiful.
Ivan,
Just delicious with all its details. The colour is so of its time, love it all.
Thanks,
Thanks,
