3 into 1 pipe
- Country: canada
- Suzuki 2-Strokes: 1976,1975,1973 gt 750
Re: 3 into 1 pipe
I could post some pics, I think it is the same pipe that omar sells if that is any better for you.
Re: 3 into 1 pipe
I haven't seen any decent pictures of Omar's pipe either. The usual pic is 2" x 2" and doesn't show much. It would be interesting to see what it actually looks like. Thanks
- Country: canada
Re: 3 into 1 pipe
pipe
- Country: canada
Re: 3 into 1 pipe
i like it, they say it sounds like a ferrari
- Country: canada
Re: 3 into 1 pipe
could you tell me proper route for choke/clutch/throttle cable on the k model. i am seeing it in different places on different pics, thanks in advance.
Re: 3 into 1 pipe
Info supplied on Ian's site http://www.oldjapanesebikes.com/fieldgu ... iring.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;diablo wrote:could you tell me proper route for choke/clutch/throttle cable on the k model. i am seeing it in different places on different pics, thanks in advance.
- Country: canada
Re: 3 into 1 pipe
yes that is the first place i looked, could not see where the choke cable goes and mine don't seem to fit right. I gess i will have to measure it to make shure it is the right one.
Re: 3 into 1 pipe
Nice looking pipe. What is the baffle design - Is it a straight perforated tube or something more esoteric?
- Country: canada
Re: 3 into 1 pipe
yes, it is a straight perforated tube that fits into the end of the cone, lots of packing but still makes a bit of esoteric noise. I like it alot, don't have the power of 3 into 3 and it really works good on the k motor. Will get some pics up soon.
I have close to 100 miles on it working out the bugs, the float bowls seem to empty out at steady speeds above 60 mph. i set the float level at 27 mm as it shows in the diagram in the clymer book, do i have the floats set too low? shure don't want to hole a piston, did you ever have that problem?
- Country: canada
Re: 3 into 1 pipe
pics will post for me, what am i doing wrong now
- Country: canada
Re: 3 into 1 pipe
IMG_0986
Re: 3 into 1 pipe
Instructions are here: viewtopic.php?f=1&t=3098
Make sure the files are in jpg, jpeg, or gif formats.
I generally make sure files are smaller than 250kb.
- Country: canada
Re: 3 into 1 pipe
sais the file is too big, it is under 2 mb, hmm
- Country: canada
Re: 3 into 1 pipe
k
- Country: canada
Re: 3 into 1 pipe
the patriot
