XR11/73
garry55
Re: XR11/73
Post by garry55 »
Suzukidave wrote:You can make a triple chopper LOL Image
Noooooooo! that is so wrong............... :shock:
Garry
garry55
Re: XR11/73
Post by garry55 »
and the RS250 front wheel, to match.......
I've put the calipers to the front on purpose as a nod to the original XR11 / TR750 racers, on which this project is loosely based.
waiting for the headers to be modified now, to see if they will clear the front tyre.
Garry
Re: XR11/73
I have been trying to find in my picture files a Kawasaki race bike that had the steering neck part of the frame welded to a plate and another plate welded to the front of the frame . It was setup so they could put different spacers or wedges in to adjust rake n trail and wheel base . I was close to doing the mod myself on my Srad frame till i got the engine pipe angles figured out . I will post the picture if i can find it , just in case you could use something like that .
Re: XR11/73
I am pretty sure it was a KR500 https://www.google.com/search?q=Kawasak ... B737%3B417" onclick="window.open(this.href);return false;
garry55
Re: XR11/73
Post by garry55 »
thanks for the heads-up Dave - I looked at this KR500 at Sammy Millers museum here in the UK but don't remember that set-up on the monocoque frame.
But then factory race bikes differed from month to month - I would be intrigued to see the detail of it.
I'm hoping I have solved the clearance issue by removing one and three quarters of an inch from the straight section of each header pipe. By my reckoning that will allow the wheel to clear on full compression.
He said, hopefully............. :o
Garry
Re: XR11/73
What really worried me was if the wheel cleared under full compression , i measured front wheel travel and then lowed the forks in the yokes that amount to simulate it . It was very close with the pipes tucked in as i did with 13mm clearance on the center pipe at full compression :shock:
old racer
Country: Wales
Suzuki 2-Strokes: RG250 GT750L GT750 DRAG seelyt500 tr500MK3
Re: XR11/73
Post by old racer »
Don't forget forks bend, at the same time as they compress under heavy braking.
Re: XR11/73
old racer wrote:Don't forget forks bend, at the same time as they compress under heavy braking.
Yeah .. thats why the 13mm gap had me wondering about contact on mine . Hopefully the inverted forks dont flex much :up:
garry55
Re: XR11/73
Post by garry55 »
I doubt you will get any flex from the USD forks Dave - they are strong enough to snap the headstock off bikes with barely a trace of bending! I have recovered many race bikes with totalled frames and the USD forks looked OK. The RWU forks do flex (and bend in an accident), but I run mine dropped through the triple clamps to improve front-end grip anyway, so that shortens the already short length of "exposed" stanchion. And they are quite beefy 41mm stanchions.
Garry
Re: XR11/73
garry55 wrote:I doubt you will get any flex from the USD forks Dave - they are strong enough to snap the headstock off bikes with barely a trace of bending! .
Good to know , my project bike is the first bike i have owned with the inverted forks .
garry55
Re: XR11/73
Post by garry55 »
USD forks are very good - especially for racing, as they are very "tuneable".
I much prefer RWU forks though, as I find USD forks too stiff and lacking "feel" (read flex!). Guess I'm just plain old-fashioned!
Garry
garry55
Re: XR11/73
Post by garry55 »
making the timing-side cover
a bit of mechanical assistance never goes amiss
before having to resort to manual labour
the previously made spacer plate was deemed a tad too thin to weld without distorting, so out with the Araldite :D
now set aside to dry for several hours......................
Garry
garry55
Re: XR11/73
Post by garry55 »
...............leaving plenty of time to address this home-made (by someone else) left-side shortened cover, kindly supplied by a guy off the Kettleclinick forum. Thanks Mike :D
before.........
and after the application of a grinder and file.........
and fitted
and the other cover in situ
Garry
Re: XR11/73
Quite a transformation ! :up:
Re: XR11/73
That is one incredibly thick outer cover. Is that for slide protection? I just had one cut from 3/16" plate. :shock:
