T500 Cylinders Ported and bead blasted. Will need new pistons. Currently .5mm over. Porting good for street or track. Will work with stock carbs or aftermarket. Also will work with stock modified exhaust (baffles) and chambers.
$350 exchange (cylinders also must be max .5mm over)
Will raise transfers for an additional $50 per cylinder.
Ported T500 Cylinders
- Zook-e
- Smokin'
