STA-BIL
- Country: usa
- Suzuki 2-Strokes: gt750A
Re: STA-BIL
I swear by it. I have never had any carb problems from bad gas since I started using it years ago!
Re: STA-BIL
Yes.Coyote wrote:does it work?
Re: STA-BIL
Yes.
I've had a snow blower for quite a few years.
After a few years of leaving gas in it over the summer, the carb jets got so plugged up it wouldn't start.
I now fill the gas up + add Stabil in the spring & then run it for a while to get the Stabil in the carb.
For this recent winter season, it started on the first attempt.
Started using Stabil something like 8 years ago & haven't had any starting problems since then.
Re: STA-BIL
+1 also a convert. Its 'supposed' to work and as far as I can tell as I've not had any over wintering problems it probably does do what it says on the bottle!
Re: STA-BIL
- Country: U.S.
Re: STA-BIL
Start the bike and allow the additive to cycle through the carbs. Otherwise, the old gas without it. Has a chance to gum up inside the carbs.
- Desert_75
- Suzuki 2-Strokes: '75GT750, '79CX500, '08ZX-14
Re: STA-BIL
I run it through my boat when I store it through the winter, hasn't let me down in 4 years.
- Flywheel
- Suzuki 2-Strokes: 1974 GT185
Re: STA-BIL
So what would be the better procedure for winter storage: Add Sta-bil to the gas and run/cycle it thru the carbs or drain the tank and carbs completely?
- Country: U.S.
Re: STA-BIL
If it's me. Six months or less doesn't get any treatment. I remove and clean my carbs every couple of years anyhow. I'd say if you're gonna let the bike set for over 6 months. Drain all fuel. Less than 6 or you're not a guy to remove and clean carbs that often. Add the Sta-bil.Flywheel wrote:So what would be the better procedure for winter storage: Add Sta-bil to the gas and run/cycle it thru the carbs or drain the tank and carbs completely?
- Flywheel
Re: STA-BIL
pearljam724 wrote:If it's me. Six months or less doesn't get any treatment. I remove and clean my carbs every couple of years anyhow. I'd say if you're gonna let the bike set for over 6 months. Drain all fuel. Less than 6 or you're not a guy to remove and clean carbs that often. Add the Sta-bil.Flywheel wrote:So what would be the better procedure for winter storage: Add Sta-bil to the gas and run/cycle it thru the carbs or drain the tank and carbs completely?
Something to think about for sure. I usually put the bikes away in November draining all fuel. Bringing them back out now. Approx 6 months. Cleaned both bikes carbs last summer. Maybe this coming fall I'll just try the stabil. Thanks for the tip
- Country: U.S.
Re: STA-BIL
Flywheel wrote:pearljam724 wrote:If it's me. Six months or less doesn't get any treatment. I remove and clean my carbs every couple of years anyhow. I'd say if you're gonna let the bike set for over 6 months. Drain all fuel. Less than 6 or you're not a guy to remove and clean carbs that often. Add the Sta-bil.Flywheel wrote:So what would be the better procedure for winter storage: Add Sta-bil to the gas and run/cycle it thru the carbs or drain the tank and carbs completely?
You're welcome. If you have a Big Lots nearby. Stop by every now and again. They usually have it on stock for an outstanding price. I bought 2 full size bottles less than a year ago. For $2.50 a piece. Most competitors sell it for roughly $5 a bottle. That cheap, had to grab a couple. As far as carbs, it's best to drain fuel. Most carbs have a drain bolt at bottom of bowls to avoid having to remove the complete assembly. But, I like to keep my tanks completely full to help avoid rust. Those that aren't sealed. But, my understanding. A tank that is full of fuel can still be subject to rust. Just not as easily. It's never a bad idea adding the Stabil. They say ethonal based fuels only have a shelf life of about 120 days. In years past, gas had a much longer shelf life. Approximately a year. Today's gas absorbs a lot of water. I've never had a problem storing it for 6 months without stabil. But, it's wiser to use the stabil with ethanol treatment over 6 months I'd have to say.
- ConnerVT
- Novice racer
Re: STA-BIL
It is a little bit of work, but to keep my tank full of fresh fuel, this is what I did this winter. My bike is parked next to my snow blower in the garage. When the gas can for refilling the snow blower gets low, I refill it from my bike. I have a gas line to attach to my petcock, which is long enough to reach the 2 gal gas can. I then take my empty 2nd gas can to the station, buy fresh gas, and refill the bike.
