Mine is harder than Chinese Arithmetic. Is it supposed to be a hard line because it's on the suction side of the pump, or can it be replaced with a new, softer line like Tygon or fuel hose?
Also, there's a fitting in the line about 3 inches from the bottom of the tank. Can't tell if that's a check valve or a jury rig from a previous owner.
Line from tank to oil pump on GT550
- Country: United States
- Suzuki 2-Strokes: 1979 Yamaha XS650, 1974 Suzuki GT550
Re: Line from tank to oil pump on GT550
I've just got normal clear plastic pipe on both my 550s.
- ConnerVT
- Novice racer
There is no suction on the supply side of the pump. It is gravity fed.
I used tygon on my T350.
Excellent! Thank you all for the replies.
