RV125 - ignition switch not affecting ignition
General discussion about Offroad two-stroke Suzuki motorcycles.
Ben
Suzuki 2-Strokes: 1 too few
Post by Ben »
Hi Guys.
Working on a late 72 RV125.
Issue: the 3 position key ignition switch does not shut bike down or keep it from starting.
All 9 pins I checked with a multimeter and have continuity, switch seems good.
Bad ground?
Ben in Canada
71 CB500
74 RV125
75 RV125
84 RZ500
85 RZ500
94 DAJIBAN
00 VFR800
Re: RV125 - ignition switch not affecting ignition
post a pic of the wiring diagram and we may be able to help.
Wiring diagram is here: viewtopic.php?f=9&t=10789
Looks like your bike shuts the magneto ignition off by grounding it to the switch housing.
If you've done something like powder coat the frame, then you have eliminated the switch ground.
