1972 Suzuki T500 motor case
quidger
Suzuki 2-Strokes: T500
Post by quidger »
I was changing oil and discovered a small half rounded hole on the seam on the lower engine case where it mates with left side cover. The previous owner tried to make a screw fit into the hole that does not fit.
What is this hole for and should it have a bolt or screw threaded into it?
Re: 1972 Suzuki T500 motor case
That little notch in the bottom crankcase half is also in the crankcases listed on eBay.
Crud tends to accumulate there & it looks like Suzuki intended the notch to be a drain.
