float level
- Suzuki 2-Strokes: ts125, ts185, gt750k, gt750j
float level
Hi guys, Have been off line for only five years (have had a few life problems). Dug 1973 GT750k out of back of shed to try to finish project. Having problems with float level, fuel leaks out of carbs at bowl gasket. set at 27mm.
Re: float level
Congrats on getting through life's problems & getting back to your Suzuki.
If the carbs start leaking after the bike has been sitting for some time like over night or a few days, then suspect a leaking petcock.
If one carb starts leaking rather quickly, then suspect a sunken float. I had this happen to a T500 that was fine before putting it away for the winter — fuel leaked badly out of one carb when I tried to start it in the spring.
A bit more info would help us come up with useful advice.
- Country: WALES
Re: float level
How clean are the carbs ? If float needle valve has any debris in it it won't switch off fuel. Just checking that the Petcock is in on or reserve but not prime?
98 carb Blackbird and GT550j
Re: float level
I checked float level of each carby on bench with no problems. needle & seat holds. But fitted to bike they leak. Carbys seem to tilt forward when on bike. Maybe needs float level lower
- Country: WALES
Re: float level
Hi
The fuel level is critical to the running and performance of the bike and it has to be set at the stipulated level or the bike will either run too rich or worse too lean. Just want to confirm that the float level was measured from the carb body and not the gasket and with the carb tilted at 45 degrees and the tang on the float just touching the extended spring part of the float needle valve?
Re: float level
You can confirm the actual fuel level by using a fuel level tool.
https://www.z1enterprises.com/fuel-leve ... uzuki.html
Check the fuel level with the carbs horizontal. This shows the correct level on a GT250 carb:
Re: float level
Thanks jabcb ,have used fuel level tool and same as your photo on bench but i am thinking when on bike it may different
Also thanks GTandcbr ,have set float levels the same as you described. But maybe i am out on measuring,
See the carby tilting forward .
- Country: WALES
Re: float level
Another thing to consider is warped float bowl rims. Over time the alloy becomes slightly warped and therefore doesn't seal properly. This can be sorted by rubbing the bowl on a piece of fine emery paper laid on a pane of glass and gently sand it level.
May be worth a try?
May be worth a try?
- Country: England, UK
Re: float level
I seem to remember one guy on here recommends making your own viton rubber gaskets and finds that helps
Re: float level
Removed float bowls and checked for warping. And they were warped, sanded as GTandcbr suggested. a lot better but still weeping .May need to replace gaskets. Good news the motor started for the first time after rebuild and stayed running without starting a fire (no fuel running across floor of shed)
- Country: WALES
Re: float level
Thanks GTandcbr ,I have ordered new OME Suzuki gaskets from my local dealer ,still available.
Re: float level
Fitted new suzuki gaskets and all good now.
Re: float level
excellent. glad you got it sorted
