Good evening
can anyone help with the following problem
I took my fuel tap apart to ensure it was clean but when i have put it back together again i notuce petrol flows when the tap is turned to prime and reserve but not when its in the on position
This is when the bike is not running as the carbs are getting sonically cleaned at the moment
my belief is that the petrol should not flow when the bike is standing and the fuel tap is set at reserve.
I havent renewed the inner circular 4 holed rubber seal -could this be the problem .
fuel tap leaking -GT 750j
- Suzuki 2-Strokes: T 250 t500 gt 550
- Country: us
- Suzuki 2-Strokes: GT
Re: fuel tap leaking -GT 750j
I would say yes, if there is a bad spot on the seal it can leak into one of the other ports and bypass the vacuum plunger that controls on and reserve, which only flow when engine is running. These plungers are known to leak by sometimes not stopping the flow, but it sounds like yours is stopping flow when in on position, so I would change the inner 4 hole seal first.Monkey man wrote:I havent renewed the inner circular 4 holed rubber seal -could this be the problem .
Unless fuel level is below the on position.
part number 44376-31050
