Nippondenso Alternator
Hush
Country: New Zealand
Suzuki 2-Strokes: 74 GT550 L 73 GT250K
Post by Hush »
My 74 GT550 came with a Nippondenso alternator, after rebuilding the engine I finally get around to doing the electrics and find I have a major short which I track down to the alternator, the green wire has been attached straight onto the alternator with no insulating washers. My question is, what do they look like and can I get some from somewhere? Anyone have a photo of them so I can get some idea.
Re: Nippondenso Alternator
The parts diagrams doesn’t show it, but there is an insulator between the green wire connector & the washer.
There may also be an insulator separating the screw threads & the green wire connector, or it may be designed in a way that precludes contact between the threads & connector.
ImageGT550_Stator_1345 by jabcb, on Flickr
Not very clear, but parts detail here - https://alpha-sports.com/suzuki_parts.htm" onclick="window.open(this.href);return false; - pick year, model, denso alternator. I'll try and remember to get a pic of one when I go in the garage next time. I have probably got spares too.
Hush
Post by Hush »
I found an old petrol filter that seemed to have hard enough plastic and cut it down then used a Dremil to shape it, took about an hour during advert breaks while watching a movie. Worked perfectly.
dollydog
Country: england
Post by dollydog »
i'd have used an old washer off an oil banjo - nylon :lol:
Hush
Post by Hush »
Washer wouldn't work as it needed to be shaped to fit into the section.
rodent
Suzuki 2-Strokes: '73 GT750
Post by rodent »
Some plastic tubing that fitted inside some fibre washers would get you out of trouble.
