Exhaust bushings
markj
Exhaust bushings
Post by markj »
I'm ready to take all my stuff to the powder coater with the exception that I haven't been able to get the muffler hanger bushings out of the frame. Any suggestions? I could chance it and leave them in there but I'm sure they'll get ruined by the 400 degree oven. On the other hand I'm not so sure I wouldn't ruin them trying to get them out in the first place.
Followup - The powder coater said we might just as well leave them in there. He didn't think they'd suffer too much and they are just REALLY in there.
Re: Exhaust bushings
Mark,
I had the same issue earlier this year and I cut them out with a hacksaw IIRC. Fortunately, getting new ones in is easy. A length of allthread and a couple of sockets and they pull right in. It may be possible to use that same technique top get the old ones out, but mine were stuck.
markj
Post by markj »
tz375 wrote:Mark,
Hey thanks tz. I sort of thought that getting them out might involve distorying them. We'll see how they survive the powder coat oven. If I have to I'll "carefully" cut them out and try not to damage the finish. But hopefully they'll be ok.
I left mine in when I had my frame powder coated last year - while probably not recommended, they do not seem to have suffered at all. 8)
Leave them in. The old ones are tight and new ones are even tighter. I spent days wirh a hone on my 550 trying to get an acceptable press fit on the new ones. Finally got them in but not flush. Actually sheard off several grade 8 'pressing' bolts in the process and turned a stack of washers into funnels. Oh the language! :shock:
On the flip side, I left them in my buffalo frame. 4 large washers and 2 bolts and nuts to mask them. No harm after the trip through the oven. One problem that did occur was the coating 'bridged' the washers. I had to carefully score around each one with an exacto knife so as not to chip the coating off the frame when I knocked them off.
Looking back (hind sight is always 20/20) if I had it to over again on the 550, I would have slit them nearly through to give them room to collapse.
markj
Post by markj »
You're right Chris. I just left them in and the powder coating process didn't seem to hurt them in the least. If I ever have to get them out I would probably cut them from within and then pull them like Richard did. But I aint gonna unless I have to. :wink:
Getting them out was not a walk in the park either. Normal 'extraction' methods were shelved after much sweat and aggrivation. Here's what they looked like when I finally got them out............
Here's a little tool I designed to help pull the new ones into place. It worked for a while till the .200 thin lip colapsed. They were just tooooooo tight :evil:
