Ok, maybe someone can set me straight. I am restoring a '72 GT380 and it is about 95% done. When I kick the starter it goes done ok, still very tight, I guess for the complete engine overhaul. The problem that I am having is that the kicker will not automatically return to its original position when kicked over. It will return by hand and the rubber part can actually be pushed all the way to the cylinder. I have the punch marks lined up on the shaft and kick starter piece. Is there a trick that has to be done to make it operate correctly?
Any and all help will be appreciated.
thanks,
John
1972 GT380 kicker not wanting to automatically return
Re: 1972 GT380 kicker not wanting to automatically return
Have you had the bottom end apart?
It sounds like you haven't got the return spring loaded up...........
- advant63
- Country: canada
- Suzuki 2-Strokes: m12 or50 a100 s32-2 s32-2 t250 gt250 t500r
john, i had the same problem on my 550 which i believe i have fixed.
i don't know if the 380 is the same as the 550 or if what i did is a proper fix so beware.
while installing a boyer ignition and replacing the original scarred up clutch case i noticed that the tab on #2 was not resting on the ramp of #6 when at rest.
i originally thought that i had broke the return spring #19 but by removing #6 and preloading #2 it now holds the kickstarter in its' rest position.
the kick starter functions as i remember but i wonder if the end of the spring #19 has jumped out of the slot on #20 an is catching on the case instead, giving it tension.
anyone else?
anyone else?
m12 or50 k10 a100
s32-2 s32-2 t250r
gt250 t500r gt550a
twin cobras in baskets
s32-2 s32-2 t250r
gt250 t500r gt550a
- Scorch
- Born to ride
It's tricky! Here's my repair journal, about 1/2 down is a section on the kickstarter and mechanism, with a video. Hope this helps.
Thanks, I think I have it now. The trick was the 3/4 counter clockwise turn to lock it in place. It's been about 40 years since I actually worked on one of these.
Thanks again for all the feedback. I'm pressing forward.
