Stubborn brake bleeder - problem solved!
RING_DING
Suzuki 2-Strokes: 1974 GT750 B-4 (JDM), 1975 GT750M
Post by RING_DING »
This brake bleeder will not budge. I've soaked it in WD40, but still no movement. I'm afraid I might shear it off its stuck so badly. Any ideas?
djfisher22
Re: Stubborn brake bleeder - any ideas?
Post by djfisher22 »
put pressure on the wrench and whack the top of the bleeder sharply with a hammer.Oughta work.
72 GT750 (almost done)
73 RV 125
72 RV 90 X 2
djfisher22
Don't forget the liquid wrench or PB blaster soak first.
73 RV 125
72 RV 90 X 2
Roy it may still shear off if you whack it suddenly, try a bit of heat first around the body where the bleeder bolt is. One of the little hand-held butane torches will warm it up enough to expand the aluminum somewhat and help release its grip.
RING_DING
Post by RING_DING »
Well it came out without shearing luckily! I did as DJ suggested...let some Liquid Wrench soak in for a while. Then I gave it a couple of light taps as I applied the turn to the wrench.
Re: Stubborn brake bleeder - problem solved!
:up: :up:
Lucky you then, thats great news.
Scorch
Born to ride
Suzuki 2-Strokes: 1975 GT380
Post by Scorch »
Yeah, that's scary :?
