380 pipes on a 550 will they fit??????
andyp666
Country: Ireland
Suzuki 2-Strokes: gsx 1100 efe, gt550, ts125, 1200 bandit
Post by andyp666 »
I found a set of 3 into 1 expansions for a GT380 does anyone know if the actually fit Dimensionally???? Im not too concerned about tail bracket that can be adjusted just if they go on the engine studs and still fit under the block?
Re: 380 pipes on a 550 will they fit??????
No. The cylinders are closer together on the 380, the pipes on the 550 are larger diameter, the engine is taller and they aren't right.
Other than that, they're perfect.
andyp666
Country: Ireland
Post by andyp666 »
How about coming down from a 750 to a 550 similar thing I spose'.... I can find pipes for every model but mine, always the way...
Lorenzo
Country: Italia
Suzuki 2-Strokes: RG500 CR500 GS1000G
Post by Lorenzo »
Alan, should you not expect better performance from three single pipes anyway?
Better styling too...
Lorenzo
Country: Italia
Post by Lorenzo »
Yup. 3 into 3 runs better top end, 3 into 1 is better bottom end but tends to get strangled at high revs as three exhausts are trying to get out of 1 pipe end!
The reason that I will be fitting a 3 into 1 on my 550M when I get it done is because there's already one on there!
It should be slightly better for acceleration anyway and that's what I'll be using, not top end.
'Fraid so Andy, just put a request on all the suzuki forums and a search on ebay so if any exhausts come up you get to know straight away.
andyp666
Country: Ireland
Post by andyp666 »
Yeah just a waiting game now and see what turns up, the real pain is years ago I had a lovely set of spannies for a 550 and gave them away grrr.
