T575 Steam Triple
Moderators: Suzsmokeyallan, H2RICK, oldjapanesebikes
- garry55
T575 Steam Triple
I had a spare hour...............
Garry
Re: T575 Steam Triple
Well, that'll keep you occupied for a few nights!
- RING_DING
- joolstacho
Ooh that chain-line looks VERY suss!
- garry55
joolstacho wrote:Ooh that chain-line looks VERY suss!
it's 4mm low at the sprocket - adjustable rear engine mounts will correct that.
Garry
- garry55
daft idea #1 - turn the T595 coolant expansion tank into the 2T oil tank so it fits under the seat and out of the way.
Buy a long-reach alloy wheel valve off the worlds favourite auction site........
cut off threaded end where valve core fits..........
drill several holes in the tank (1 for the valve, 1 for the hex key) and attach.........
plug the hole for the hex key insertion and the hole where the coolant pipe originally attached and it's done.
in situ...............
and the outlet.............
Garry
- garry55
whilst I await the manufacture of the rear upper engine mounts, I turned my attention to the induction side of the motor.
There isn't a great deal of space afforded by the T595 fuel tank and the standard T595 airbox wont fit the GT750 carbs because the
spacings are way out. I tried a GT750 L/M/A/B airbox but that was way too big and wouldn't even fit between the frame rails.
So then I tried a GT750 J/K airbox but again, too big.
The only option left was to fabricate something similar to the "pancake" air filter unit fitted to the early BSA and Triumph triples.
Starting with a fit-for-scrap later version GT750 airbox............
and adding a touch of angle grinder fitted with cutting disc........
and a bit of trimming...........
left me with the component parts........
to make this "slimline" induction filtration unit.........
off to the welders it goes........
Garry
- garry55
rainy day here in North East England, so I spent a couple of hours staring at this.............
which prompted me to do this to the T595 Daytona wiring loom I purchased off ebay......
top left - redundant wiring for my "spare-wire" box
top right - waste bin fodder
bottom - super-light T595 harness.
the remains of the T595 harness, loosely draped around the frame before I get around to taping it up.......
Garry
- garry55
Genuine Triumph fuel tank gasket.............
used as a template for a water-jet cut blanking plate........
the aluminium plate is to be used to blank off the side of the fuel tank that should have this fitted......
but seeing as the GT750 motor doesn't require a fuel pump or a pressure regulator, or a feed and return fuel line coupling,
I can replace all that with a single, horizontally-mounted single outlet fuel tap (with internal filter fitted) and an in-line "dry-break"
fuel line coupling to ease tank removal.
There will be no "reserve" fuel facility - instead I will be relying on the lo fuel light.
Off to ebay now to find a suitable tap................
Garry
- garry55
a bit of easy work whilst I await the upper rear engine mountings arrival.
Modifying the top upper rear motor mount...........
cutting and threading the the top rear (long) and back lower (short) lateral bracing bars / engine mount support rails..........
fitted in the "mule" frame.......
and the Steam Trip's rolling chassis..........
once the engine mounts have been fabricated and attached to the rails, they will then be welded in place.
Garry
- garry55
A mate reckons it needs some white to compliment the other colours, so.........
although it does blush when aware of the camera.........
Garry
- garry55
here's the modified fuel outlet.............
now a tap (a NOS I found in the garage) that neatly solves the filtration problem.........
and saves me having to buy a dry-break fuel coupling
Garry
- garry55
It's almost as if Triumph had an inkling that this conversion would happen in later years as they very thoughtfully
welded brackets onto the left and right sides of the sub frame............
with holes spaced just right to allow the fitment of an Electrex GT750 reg/rec unit.......
and not only that - they also put air vents in the tail piece to allow cool air to pass over the reg / rec.......
bless 'em..........
bless 'em..........
Garry
sportston
- Country: England, UK
Wow this is going to be one very sexy special. A triumph triple with a difference indeed!
- garry55
the rear / upper engine mounts...........
eccentric mounts allow engine position to be finalised before making the fixed position rear / lower brackets.
Garry
