fork oil
- 87m6chris
fork oil
1970 T500,
I'm tearing down the forks at the moment and the service manual says new oil should be 220cc
of straight 30 weight oil.
Just wondering if that is still the best recommendation or has a different oil has been found to be better?
Thanks,
Chris
Thanks,
Chris
Re: fork oil
30wt oil is way too heavy. After market Belray at 15wt would be a good choice, or you can do like a lot of us do and use ATF (automatic transmission fluid). That's what I am using in both my bikes.
Re: fork oil
Is 30wt too heavy even for fuller-figured units like myself? That's what I planned on using...
- 87m6chris
Re: fork oil
But there were lighter weight oils when these shocks were designed, wouldn't the engineers
have taken that into account with the size valves?
- H2RICK
- Country: CANADA
Re: fork oil
I think you're missing the point here, Chris. Certainly the base CRUDE was "lighter" (composed of lighter fractions than modern "heavier" crudes) but refined oils that are stated as being SAE30 or whatever each fall in clearly defined viscosity ranges. The Society of Automotive Engineers set up the viscosity rating standards donkey's years ago so that no matter where the crude feedstock comes from or what its original viscosity is, the refined SAE30 end product is the same viscosity no matter whose name is on the can or what refinery it came from.But there were lighter weight oils when these shocks were designed
Straight 30 weight is a very viscous oil and would be almost impossible to pump through the tiny orifices in the forks of these bikes. It would be almost like having a solid front end.
IF you lived in a really hot place with average daytime temps around 110*F (say, maybe, the Sahara Desert) then you MIGHT need a fork oil as heavy as a 30 weight IF you weighed 250+# and IF you were racing the bike in a 6 hour endurance contest.
GT550A Mint & Original
MBD Sufferer
MBD Sufferer
Re: fork oil
It is pretty hot here today (mid 90's) and I did have a big lunch, but I take your point. So you're using straight ATF? I have a 15 litre drum of ATF in the shed (what can I say - I own a Ford pickup!), would be handy if that works.H2RICK wrote:I think you're missing the point here, Chris. Certainly the base CRUDE was "lighter" (composed of lighter fractions than modern "heavier" crudes) but refined oils that are stated as being SAE30 or whatever each fall in clearly defined viscosity ranges. The Society of Automotive Engineers set up the viscosity rating standards donkey's years ago so that no matter where the crude feedstock comes from or what its original viscosity is, the refined SAE30 end product is the same viscosity no matter whose name is on the can or what refinery it came from.But there were lighter weight oils when these shocks were designed
- oldjapanesebikes
Re: fork oil
Like others who have already chimed in, I've run ATF in the forks for a while. No complaints.
- Rustygt550
Re: fork oil
Chris, I used SAE 30 oil in my T500 forks, I have yet to try it yet.
Dont forget the T500 has crude damping compared to the GT's & does not have the same internals. The T500 workshop Manual states that SAE 30 oil is to be used but the Owners handbook states 10-30.
- 87m6chris
Re: fork oil
Makes sense, ATF it is then.
Thanks all
Thanks all
Re: fork oil
One benefit of using ATF, outside the price, is the fact that it has additives that keep the seals flexible and supple,extending their service life. SAE motor oil does not. I can't remember when I didn't use ATF. Cheers.
Fred
Fred
Suzuki GT 750s
Ducati 750 GTs
2007 Duc 1000 GT (the clone)
Suzuki RE5s
Ducati 750 GTs
Suzuki RE5s
- Suzsmokeyallan
Re: fork oil
I dont like using ATF in forks as its sort of 'edgy' when you run it between your fingers compared to oil. I also prefer something a bit more slippery since most of these old forks dont carry slider bushings.
I use a dedicated fork oil of either the Bel Ray or Maxima brand. For the GT750 or RE5 I use a 15 weight and for the T500 a 20 weight as those forks are pretty pathetic when it comes to their internal dampening design.
For what its worth,,,ATF is not recommended in motocross front forks.
- H2RICK
- Country: CANADA
Re: fork oil
Allan +1....and another reason NOT to use ATF is the viscosity.
Nowhere on a can/bottle of ATF do you see a viscosity listed.
"Why is that ??" you say.
Well, it's because the SAE doesn't really have a hard and fast regulation about the viscosity of ATF.....or for most other stuff to do with ATF, for that matter.
When pressed, most refiners will say "It's around 20 weight.".....but that can (and does) turn out to be anything from 15 weight to 25 weight depending on which transmission manufacturer's spec the ATF meets i.e. GM Hydramatic (Dexron), Ford (2 different specs depending on which tranny you have), etc etc.
Sooooo....you pays yer money and you takes yer chances....with ATF.
My .02 worth....
My .02 worth....
MBD Sufferer
MBD Sufferer
- oldjapanesebikes
Re: fork oil
Well - yes and no.H2RICK wrote:....and another reason NOT to use ATF is the viscosity.....
Or - you can just use what you like using
- Country: Australia
- Suzuki 2-Strokes: Suzuki t500 69,71,73, Gt500 76
Re: fork oil
I also agree with Allan, as far as the T500 I always use 30 weight (when I can obtain it), they are notoriusly oversprung and underdamped
1969 T500
1973 T500
1971 T500 (being restored)
1976 GT500 (being restored)
2012 Ninja 650
1973 T500
2012 Ninja 650
- H2RICK
- Country: CANADA
Re: fork oil
Thank you for that, Ian.
It's interesting to note that Mobil Synthetic ATF (apparently the only ATF on the list) is at the lower end or is just a little lighter than SAE20 weight when measured at 40*C......and then its viscosity increases as the temp rises to 100*C where the viscosity is in the mid to upper range of SAE20 weight....but still in the 20 weight band. Interesting phenomenon and something to keep in mind. Obviously great strides have been made by some refiners in their viscosity improvers. A lot of the mineral oils get a LOT thicker at higher temps.
And to all the Titan owners my deepest sympathies for owning a set of forks with such primitive internals that require such a viscous fluid to be able to work even close to properly.
MBD Sufferer
MBD Sufferer
