The rest of the instrument is fine - but the housing is unique to that year, and from the research folks like Allan have done, also unique to Suzuki for that model, that year. So I've been looking at replacement options. Originally I had thought of faithfully duplicating the original design, but then realised that would possibly faithfully duplicate the original problem of setting up stresses in the material by having an interference or snap fit plastic lens in a plastic housing. So I'm now thinking of a one piece injection moulded design done in clear plastic, and then gauge restorers would have to paint the outside of the shell to suit. The tach and speedo housings are the same, with the obvious exception of the reset knob, which would have to be drilled by hand. At this point I am not considering duplicating the water temperature housings as they generally are not in bad shape, clean up well and seldom crack the way the tach and speedo housings do.
This is a printed 3D model I've had made from the CAD/CAM drawing I now have. It is in an opaque plastic as the model was to double check fit, shape and finishes.
With the inside ring installed.
And mounted on the clock base plate. The slightly curved lens shape is preserved.
Before trying to have a few made to further test out plastic choices and methods of finish, I'm interested in gauging what level of interest there may be from other GT750J owners/restorers- is there any ? Unit cost would be around $100 each plus shipping. PM me here, or email me at ian (at) oldjapanesebikes (dot) com
Thanks !
