Wanted: T500 tank-to-pump oil line
Part # 16810-15130 or 16810-15131
celt_rock
Suzuki 2-Strokes: T500, GT380, GS400
Re: Wanted: T500 tank-to-pump oil line
Post by celt_rock »
Yeah, I'd like one of those too... did you ever find one or end up making your own? Mine is a mess and would
like to replace it. There's one on eBay now but it's going for $80 USD!! :shock:
Slow and steady may win the race, but without loud and fast it's just a waste
I sealed the oil line with clear liquid electrical tape & used stat-o-seal washers.
Turned out that my big problem was the oil pump top oil seal.
Bloop2 sells oil pump rebuild kits on eBay.
I used the oil seals & o-rings that are in the kit with the exception of the top oil seal.
The PO had replaced that oil seal with the wrong one, which then spun on the shaft & damaged the mounting surface.
So I had to measure the actual diameters on my pump & select a seal that would work.
celt_rock
Post by celt_rock »
But this is what I've got
How many hose clamps does it take to fix a leak and yet not actually take
care of the big problem? :wink:
Actually the banjo on the right is not original to this system. That mess just after
the hose clamps was screwed directly into the banjo that is just hanging out on the
oil petcock right now. It's not pretty but I suppose it will work. I'd rather have pretty
and little chance of 2 stroke oil getting all over my nice clean engine!
celt_rock
Post by celt_rock »
By the way, don't those guys who strip bikes out in the midwest know to detach the oil lines rather than cutting them? They seem to last pretty well and you just can't get them! With all the oil tanks all over eBay right now I'd
rather see a bunch of oil supply lines instead! Instead of seats I'd like to see the bushings, spacers and bolts. It's the little things man...
You can make your own oil line:
See:
viewtopic.php?f=2&t=7226&hilit=tygon+oil+lines&start=39
celt_rock
Post by celt_rock »
what sort of pods are you running there?
alanr
Post by alanr »
http://www.trademe.co.nz/motors/motorbi ... 220367.htm" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
CB360T
TT250
