Selling out
Selling out
RedZone:
Completed bike. 1975 GT550M. Has powder coated frame, fork lowers, all engine covers, gas cap and ram air shroud (low gloss clear). New top end (1mm oversize) 434 miles ago. Actual milage shown on odometer 13,516. Morris magnesium wheels. Aircraft aluminum CNC machined bearing adapters, sprocket carrier and disc brake carrier. New Progressive shocks. New Kenda tires front and rear with new tubes. Swing arm from an 80 GS750 for wider rear tire Stock 80 GS brake stay and caliper on rear. Dual disk setup with drilled rotors front and slotted rotor rear. Stainless brake lines throughout. Fiberglass seat and front fender. Has later model Borg Warner starter clutch assembly that works perfectly. All electrics work including charging system. New battery and new battery tender.
Extra parts:
Complete set of cylinders and head. Cylinders are stock bore. Matched set of Wiseco pistons .5mm oversize and matching set of .5 over dykes style rings. Lots of gaskets for base, head and cases. As you can see, there's enough to do another top end. 2 stock swing arms. Extra points plate with new points and condensers by ND. Ignition is Kokusan. Lots of small stuff like extra side covers in primer. Asking $3000
Notes: This bike won first place 'Peoples Choice award' at a local vintage meet. Trophy goes with the bike.
The slotted rear rotor and new tires were not when these photos were taken. Handle bars have been changed and now have a 1" rise.
TLRam1
Re: Selling out
Post by TLRam1 »
What's next after you move this?
Terry
Re: Selling out
Definitely a sharp looking bike.
Did you sell it? Going to build another Suzuki?
Re: Selling out
No More bikes. Chronic lower back and hip pain. Got a nibble on this one from a lad in California, but nothing gas jelled yet.
TLRam1
Re: Selling out
Post by TLRam1 »
Don't leave Sundial, you are a wealth of information.
Terry
H2RICK
Country: CANADA
Re: Selling out
Post by H2RICK »
Sorry to hear about your back probs, Coyote.
I hope Red Zone goes to a good home. You did a great job on her. :up: :clap:
That bike is very much like what I intended to build ~15 years ago. I even bought a 550M
as the foundation because it had a nice set of Bassani chambers on it. Well, one thing led to another
and I built my H2A semi-hot rod instead and the poor 550 ended up getting parted out.
IIRC, the pipes were sold to a member of this board in 2002 or so.
GT550A Mint & Original
MBD Sufferer
Tomb
Suzuki 2-Strokes: TW200, R1200RT
Re: Selling out
Post by Tomb »
Hi. I interested in this bike. Please call me at 908 883-0771.
Tom
