T500 oil lines
- Suzuki 2-Strokes: T500 GT550 RM125 RM250 TS250 RM400 CR250,
T500 oil lines
Anyone have a source for crank case oil lines? Anyone ever make their own? Any subs for factory tubing? Thanks in advance.
Re: T500 oil lines
There is a thread on here with a member making and supplying new valves for your old lines.
Re: T500 oil lines
Thanks, couldn't find the thread. Found one where a guy was making new lines using Polaris check valves but didn't work. Wrong psi. Found a source in UK selling the correct valves but I think one of my lines is leaking around the valve. May be split. I have oil on top of my case. Any suggestions anyone?titan performance wrote:There is a thread on here with a member making and supplying new valves for your old lines.
Re: T500 oil lines
Check the junction block that splits the line into two lines.
Good chance that its leaking on the two-line side of the block.
Re: T500 oil lines
Thanks, I can see oil dripping down the line from around the check valve. If it's cracked where the line attaches to the valve can I epoxy it and use a stainless crimp style clamp instead of the collet? Does anyone have a good set of lines to sell? Thanks again. Chrisjabcb wrote:Check the junction block that splits the line into two lines.
Re: T500 oil lines
Is it dripping from a check valve that feeds the crank?
If so, it might be leaking elsewhere & the oil is just running down the line before it drips.
Re: T500 oil lines
Can a stainless crimp clamp be used instead of the metal collet to secure the hose to the check valve (link below)?
https://www.belmetric.com/images/OETsideview.jpg" onclick="window.open(this.href);return false;
