What's This?
What's This?
Is this a part? it came out of either the bag with the oil inspection window pieces or the bag with the new oil cap guts. Those are the only 2 bags I opened and it sure doesn't look like anything I've ever seen before.
Re: What's This?
Back of the oil inspection window, so you can see the oil level in front of it.
Part No. 44600-31830, lens set, oil inspection.
http://www.alpha-sports.com/suzuki_parts.htm" onclick="window.open(this.href);return false;
Pick year, model, oil tank, part 4.
Re: What's This?
No. There are 3 pcs. that come with the window replacement. A new lens, a new rubber gasket and a new metal marker that goes in the window.The metal piece has a tab that locates itself in the upper hole behind the lens. I have replaced 4 lenses and have never seen this part.
Re: What's This?
My guess would be that it's an oil baffle that fits in the filler cap.
- ConnerVT
- Novice racer
Re: What's This?
Doesn't look like the backing plate for the oil level window to me.
Looks more like the blank that gets punched out of a wiring box, for a conduit to connect.
Re: What's This?
Hey! Check out the copy of this fiche. Looks way more like that plastic piece than the metal piece. Maybe it's an either or.
