Thank you all ! The bike was imported into Canada in 2001, and I know of four others up here - there must be a few more, but likely not more than a dozen, In the USA I think there may be as many as a 100. Of the 12,000 of this model made between 1934 and 1960, at least 4000 are still on the road globally. I will eventually have a few more photos up on
my web site (and - no - I will not be changing the site name
) as I get it sorted out. It runs well, but is a bit tired and needs some TLC.
Some additional photos - note the frame was made from riveted flat bar steel, and the exposed valve springs. The engine is an overhead cam, in-line air cooled four displacing 746cc and when new put out perhaps 20 HP - this one probably has a few less
Something else to play with in my spare time at any rate !
