Hey guys, picked up a 72 gt 750 I have an extra 74 crankshaft on hand and read a little about the later cranks being better than the 72 cranks, haven't torn down the engine yet and was thinking of having the 74 crank rebuilt and swap it out in place of the 72 this is to save a little time since I have the 74 crank sitting around , can I swap these crankshaft out right or is there some mods that I should know about or just have the 72 crankshaft rebuilt and not worry about any modifications.
smokin
Gt 750 crank
- Country: us
- Suzuki 2-Strokes: GT
Re: Gt 750 crank
On my early 73 gt750 that had the early crank,I replaced with one out of a 74,I had to use 74 pistons,and the washers that go between the piston and connecting rod.
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
Re: Gt 750 crank
Info on the change http://www.suzukidave.com/index.php?cmd ... jkxMTA4NDU" onclick="window.open(this.href);return false; , http://www.suzukidave.com/index.php?cmd ... mEzZDhlNzA" onclick="window.open(this.href);return false;
Re: Gt 750 crank
I would rebuild the 74 as well. Just follow the instructions as Dave listed.
Re: Gt 750 crank
Thanks for the information, not sure if I want to rebuild 2 cranks I'll have to think about that.
Smokin
Smokin
Re: Gt 750 crank
Later cranks are better than early ones but must be used with later pistons - which happen to be what's generally available.
You can keep the old crank for back up, but few parts interchange. Bearings are teh same and crank pins, but rods and crank cheeks are different.
