2T oil leaking from viewing eye in oil tank...
Ramjam
Country: Lebanon
Suzuki 2-Strokes: gsx 750R, GPZ 750, GT380
Post by Ramjam »
If anyone can tell me how to seal the round seal of the viewing eye, i would be very grateful. WOuld silican (obviously done when the level is lower) do it? Or a poxy resin? It's only a small leak but after a few days doesn't half leave a puddle of the red stuff on the pavement.
thanks for your help
MJ
GTandcbr
Country: WALES
Re: 2T oil leaking from viewing eye in oil tank...
Post by GTandcbr »
This is a common problem this is what you need http://www.ebay.ie/itm/Suzuki-GT380-GT5 ... _69f-z9w6Q" onclick="window.open(this.href);return false;
98 carb Blackbird and GT550j
Ramjam
Country: Lebanon
Post by Ramjam »
GTandcbr wrote:This is a common problem this is what you need http://www.ebay.ie/itm/Suzuki-GT380-GT5 ... _69f-z9w6Q" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
WOuldn't just a bit of poxy resin do the trick?
Ebay doesn't work in Lebanon
MJ
karl pa
Country: us
Suzuki 2-Strokes: GT
Post by karl pa »
I sealed one of mine with a little gasket sealer,hasn't leaked for a couple of years now.
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
GTandcbr
Country: WALES
Post by GTandcbr »
I would try the gasket sealer because if the epoxy didn't work you may have to look for a new tank.
Ramjam
Country: Lebanon
Post by Ramjam »
GTandcbr wrote:I would try the gasket sealer because if the epoxy didn't work you may have to look for a new tank.
im guessing with the oil lower than the eye viewer level?
What is wrong with doing it the right way? The parts are available, and they're cheap.
Ramjam
Country: Lebanon
Post by Ramjam »
rngdng wrote:What is wrong with doing it the right way? The parts are available, and they're cheap.
What is wrong with reading what i wrote earlier? Ebay doesn't workn Lebanon.
These do, I should think.
http://www.alpha-sports.com/suzuki_parts.htm" onclick="window.open(this.href);return false;
or these
https://www.discountbikespares.co.uk/sh ... 4600-31830" onclick="window.open(this.href);return false;
But why not just remove the sightglass and put an O ring behind, then tighten up again?
Sorry, my mistake. I did not see that detail. Is shipping from the US an issue or is it Ebay in general?
Ramjam
Country: Lebanon
Post by Ramjam »
Alan H wrote:These do, I should think.
http://www.alpha-sports.com/suzuki_parts.htm" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
or these
https://www.discountbikespares.co.uk/sh ... 4600-31830" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Believe it or not, Discountbikes only uses Paypal. THIS is what dosn't work in Lebanon, when i wrote that Ebay doesn't work. It's the PP component.
Anywyay, i dind't even know you could take it out. Does it screw out? The sightglass
Ramjam
Country: Lebanon
Post by Ramjam »
No,the problem is Lebanon and paypal don' work. So it's always difficult finding a dealer in the UK or US who will first of all take a call over the phone and accept CC details.
A lot won't. And then of course you have to find one which also deals with international post.
MJ
