1969 X6 Hustler - Which piston goes where?
granitize
Suzuki 2-Strokes: 1968 T20
Post by granitize »
Hey,
I have a conundrum.
2 cylinders ... 2 pistons.
I know that the arrow point forward... but does one piston go into a specific cylinder?
When I took them out they were thick with carbon!!!
Now that they are cleaned up I notice that one has an "E" and one has an "F".
Does it matter? Other than they were in there for a long time?
"Some people know, and other's want to... Progress happens when you understand when to be who!"
sportston
Country: England, UK
Re: 1969 X6 Hustler - Which piston goes where?
Post by sportston »
Are they both the same size?
Do they both have the ring locating pins in the same place?
Do they have any holes in different places?
If the answers are, yes, yes and no, then they are interchangeable.
However, as a general rule it is advisable to always make a note of which bore they came from and put them back in the same bore.
This is so that the rings and pistons are matched to the bore they have been bedded into. If you are fitting new rings, it is less important.
Are you fitting new rings?
If so don't forget to hone the bores of the barrels.
Per the parts diagram there is only one part # for each of the sizes (standard, oversize 0.5 & oversize 1.0). So there is no left & right — they are the same.
Paul Miller has a NOS set of 1st over pistons. One is labeled “0.5” & the other is labeled “E”.
http://www.ebay.com/itm/Suzuki-T20-TC25 ... 1542745159
But another seller has a set of standard pistons labeled with “E”.
http://www.ebay.com/itm/Suzuki-T20-TC25 ... 2397853199
So your “E” & “F” might indicate different sizes.
Accurately measure your pistons + cylinders, and you should be able to sleuth this out.
granitize
Post by granitize »
Hmph...
Thanks jabcb...
They are in the cylinders now... So I either got lucky and put them back the same...
Of one is too tight.
I will do some accurate measure.
The cylinders were honed.
old racer
Country: Wales
Suzuki 2-Strokes: RG250 GT750L GT750 DRAG seelyt500 tr500MK3
Post by old racer »
Check that the ring gaps are not travelling over the ports.
Indy650
Country: Usa
Suzuki 2-Strokes: '74 GT250
Post by Indy650 »
Any time you reassemble with old pistons you should do a light hone and run the bike as a new break in. anyone can do a hone with a drill and a cheap 3 stone hone that can be bought for under 30 bucks
