cruzin image??
johnakay
I likes them jubblies
Suzuki 2-Strokes: bike
cruzin image??
Post by johnakay »
are these dealers any good or trustworthy.
I've seen a couple of negatives on here and other places.
but sometime just sour grapes.
I seem to remember Peter Odell had problems from these folks running off with his money on conrods.
seen these one ebay.
thought these were complete discontinued.
I know one time Crooks did a batch but using outer all case's.
http://www.ebay.ca/itm/SUZUKI-T500-GT50 ... 9#shpCntId" onclick="window.open(this.href);return false;
Re: cruzin image??
There have been the odd issue or two from time to time. I have bought and used GT750 and GT550 pistons and gaskets and intake rubbers and other parts and so far only one clamp was a problem out of dozens of transactions. I have installed several sets of their pistons and even though they are cast and not designed for racing, I have run then for several years now in my drag race bike which is regularly revved to 8,000 or more. I would not recommend that anyone else repeat that, but they are perfectly good for any street motor.
I have no experience with the big end parts but would have no problem using them in a street bike. They are really good at answering questions and have often refunded shipping when I ordered several parts at once they passed those saving back to me.
dollydog
Country: england
Re: cruzin image??
Post by dollydog »
agree totally with tz, never had a problem with anything i've had off cruzinimage :D
ordered parts on thursday night and received on next tuesday morning. japan to england :D
pity half the uk sellers aren't as quick or reliable with their goods :cry:
old racer
Country: Wales
Suzuki 2-Strokes: RG250 GT750L GT750 DRAG seelyt500 tr500MK3
Re: cruzin image??
Post by old racer »
Apparently the above bearings had the oil hole drillings in the wrong place.
Vintageman
Re: cruzin image??
Post by Vintageman »
So far I am the odd man out. I have bought several things from him/her (pistons, gasket etc.) and all were a bit off . Would these flaws affect reliability? Reason tells me it could. After all the effort and money I put into my bikes, having Peace of Mind as I run mile after mile is priceless. I never used any of the pistons due to reverse engineering dimension/tolerance issues and gaskets I used failed and leaked.
With that said I was very interested in his GT550 rods. If they are out of spec, I won't use. One would think these could be reversed engineered very easily and verified before sold. Right?
73 Kawasaki H1 500
Re: cruzin image??
Vintageman wrote: With that said I was very interested in his GT550 rods. If they are out of spec, I won't use. One would think these could be reversed engineered very easily and verified before sold. Right?
In the latest issue of Classic Mechanics, there's an article by Stan Stephens about rebuilding a 550 motor. It mentions the conrods are NLA, and uses a Kawasaki rod with some modifications. I'll try and remember to look it up and post what it says here.
Vintageman
Re: cruzin image??
Craig380 wrote:In the latest issue of Classic Mechanics, there's an article by Stan Stephens about rebuilding a 550 motor. It mentions the conrods are NLA, and uses a Kawasaki rod with some modifications. I'll try and remember to look it up and post what it says here.
That would be awesome
73 Kawasaki H1 500
Re: cruzin image??
Sorry for the delay in finding the info. The article covers a full rebuild and 'fast road' tune of a GT550. Stephens mentions that Suzuki rods are NLA, and says his crank rebuilder (Grampian Motors, pretty well known in the UK) uses rods from a KTM 200.
Here's the link to a PDF I made of it, it's a bit vague on detail but Grampian Motors seems to have rods, crank seals etc. I don't know if they will sell these parts for you to use, or if they only sell them as part of a rebuild.
Article link: https://nofile.io/f/efzC91PhYcy/GT550+rebuild.pdf" onclick="window.open(this.href);return false;
johnakay
Re: cruzin image??
Post by johnakay »
didn't Peter Odell gave them 3 grand for t500 conrods only to keep the cash and not honoured the deal a couple of years ago?
Re: cruzin image??
Thanks for that link.
Vintageman
Re: cruzin image??
tz375 wrote:Thanks for that link.
+1
Couple mistakes.
-The std bores/stroke 60mm/61mm
-I doubt if you can bore more than a couple mm OS, like the gt380 liner thick on bottom but get thin on top
-Run gas oil mix suggestion, not on that engine
I think someone here did the KTM 200 rod swap 2-3 years back but the person who did it for him forgot the 1mm extra length initially. But that is not that too much to correct and not a bad idea. Forgot about that rod swap. Also the crank pin for gt550 is still available from Suz. rods for KTM $60.00 on ebay at the moment.
What sucks is the crank pin for GT380 is not available. Separate post coming
73 Kawasaki H1 500
Re: cruzin image??
Vintageman wrote: Couple mistakes.
Yes, I noticed the petroil suggestion too ...
You're right, SEP rebuilt a 550 motor but didn't use spacers under the cylinders, so the pistons were clipping the head gasket or head.
Re: cruzin image??
IIRC, 550 rod is 117mm Ctr to Ctr and KTM is 118mm - BUT the 550 pistons are typically 0.5mm below deck at TDC, so all it should (small word with enormous implications perhaps) need is a 0.5mm thicker base gasket. Or if machine the heads slightly to provide optimum clearance.
The article by Stan Stevens did suggest that a KTM rod was not a straight swap but forgot to tell us what the problem and fix were. :?
tricky1962
Country: United Kingdom
Suzuki 2-Strokes: T500J
Re: cruzin image??
Post by tricky1962 »
Vintageman wrote: -Run gas oil mix suggestion, not on that engine
He does say - if he was tuning it for maximum power he would run it on premix - the T500 can be modified to run on pre-mix, I'm guessing Stan knows how to mod GT550s to run on premix too
Vintageman
Re: cruzin image??
tricky1962 wrote: I'm guessing Stan knows how to mod GT550s to run on premix too
Maybe he's getting confused and thinks it's a Yamaha :wink:
73 Kawasaki H1 500
