changing speedo bulbs
Monkey man
Suzuki 2-Strokes: T 250 t500 gt 550
Post by Monkey man »
Can anyone advise how to access and change the bulbs in the speedo and tacho on my Gt 750 j
Haynes manual doesnt make it clear
karl pa
Country: us
Suzuki 2-Strokes: GT
Re: changing speedo bulbs
Post by karl pa »
I believe you remove cable, then the two screws holding back cover allowing cover to be removed, then remove nuts and washers allowing tach/speedo to be removed from bracket, there are spacers in the bracket cushion that may come out when meter is removed, bulb sockets are pushed into holes in the back of meters, these you wiggle and twist to remove, they can be stuck in place so care must be taken not to tear the rubber.
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
daxman
Country: United Kingdom
Post by daxman »
Monkey man wrote:.. Haynes manual doesnt make it clear
No way.
