T575 Steam Triple
garry55
Re: T575 Steam Triple
Post by garry55 »
sorting the Steam Trip's electrics........
3 out of 6 so far.............
Oil warning light is for 2T oil tank level. Unused "Engine Malfunction" light (at the bottom) has been wired-in as a side stand warning light, but I am awaiting the relay for it to be delivered.
The redundant electric starter motor button has been wired-in as a check function for the 2T oil tank warning light.
Garry
garry55
Post by garry55 »
Busa1300 - sorry for the delay in replying to your question about the front calipers.
They are 83mm centres.
Regards,
Garry
busa1300
Suzuki 2-Strokes: RGV RGV RGV RGV ......
Post by busa1300 »
garry55 wrote:Busa1300 - sorry for the delay in replying to your question about the front calipers.
Regards,
Thanks Garry, I just got a set for my TZR/SP.....about 1/8th the price of the same caliper with Nissin cast on them...(TZ250)
MY TWO STROKE ADDICTION
TZR250SP 3XV2...
RS 250 Cup bike
RGV VJ21 L
RGV VJ22 FL
RGV VJ23 T
RZ 350
GT 750 J....sold.....
SX-R 800
KD 80
JR 50
RZV 500 R
https://www.youtube.com/@wedgehorsepower9869/videos
garry55
Post by garry55 »
can't believe I've got this far and only just noticed that with the standard 40mm CV carbs and fuel tank fitted, there is no room for an air box
so I had a root around in the garage and found some 32mm slide carbs as fitted to the RGV250's, then unearthed a set of 3 new, boxed 34mm OKO Keihin copies.
The RGV carbs were discarded and the set of OKO's fitted using modified carb-to-barrel inlet rubbers.
I now have 4" of room in which to fit an air box, which is away for fabricating.
You can see the difference between the standard carbs and the OKO's in the following pictures.
Garry
garry55
Post by garry55 »
This arrived from Germany yesterday.................
so today I made a temporary bracket for it to fit where the Triumph's fuse box used to live...........
like so................
I'll wire it in tonight, then spend the rest of the week attempting to programme it!
Garry
garry55
Post by garry55 »
M Unit installation part 1
The M button is the tiny cylindrical gizmo with the coloured label on.
To the left of that is a 6-way connector (only 4 in use at the moment) that connects the l/h handlebar switches to the M Unit.
They are:- lights, horn, left indicator and right indicator.
To the right of the button is a 3-way connector (only 1 in use so far) that connects the r/h switch.
The spliced black wire is 1 from the front brake switch and 1 from the rear brake switch.
All these signals connect to the M Unit via the thin green cable.
The blue cable is for the starter button (redundant on this build).
The black cable is an earth connection.
Simples.
Here it is with all the earth wires connected too and sheathed in plastic.
The redundant T595 harness has a lovely earth cable that runs from the battery and then splits into 10 different feeds -
absolutely ideal for this installation as the wire sizes are just right and have the absolute minimum of connections.
Garry
garry55 wrote: so I had a root around in the garage and found some 32mm slide carbs as fitted to the RGV250's, then unearthed a set of 3 new, boxed 34mm OKO Keihin copies.
Just what anyone would have 'laying about'! :clap:
Really amused me that!!! :lol:
I have lots of 'stuff' spare in my garage, but no carb (or other) exotica like you have, unfortunately..... :roll:
Ace build though, I do enjoy reading the current instalment as you progress.
garry55
Post by garry55 »
Thanks Alan :up:
I also unearthed a set of 3 Amal carbs for a T150V Trident with a set of angled T160 inlets attached + a set of 3 GT750 J/K carbs and fittings that I had cleaned and re-zinced ages ago.
I might have to forage more often............. :D
Garry
Following your build with great interest Garry. Do you have any settings for the Oko carbs?
garry55
Post by garry55 »
titan performance wrote:Following your build with great interest Garry. Do you have any settings for the Oko carbs?
On good advice (from my dyno man), I was going to run the RGV carbs with 350 mains and 35 pilots.
Then fine-tune it on the dyno.
Garry
garry55
Post by garry55 »
back to the air box - collected this today - front is GT750, top is part of a T595 airbox..........
the metal box was only tacked together as it may not fit (because I measured it)..........
it fits :up:
I was 1cm out - the 3 metal trumpets require shortening by that amount to allow the fuel tank to sit flush.
Garry
garry55
Post by garry55 »
M Unit fitted, programmed and fully operational.
The bike has gained self-cancelling indicators and a flashing / steady / flashing rear brake light.
Garry
dollydog
Country: england
Post by dollydog »
surprised you didn't use the electric leg garry. any particular reason for that? :D
Weight saving. On a hippo, every hundredweight counts.... :up:
garry55
Post by garry55 »
dollydog wrote:surprised you didn't use the electric leg garry. any particular reason for that? :D
you really don't need them on a 2 stroke DD.
and it would get in the way of the alternator....................
Garry
