1968 Cobra front fender
Slarsonroy
Suzuki 2-Strokes: 1968 T500 Cobra
Post by Slarsonroy »
Now that I got your attention, which front fender fits my 1968 T500 Cobra besides the missing original? Does a later Titan fender fit the mounts or possibly another model? At least I will have a fender.
Re: 1968 Cobra front fender
Per an old printed part manual for the T500-1 & Partzilla for the T500M:
https://www.partzilla.com/catalog/suzuk ... front-fork
The fork outer tube part #s are 51130-15011 & 51140-15011 for all T500 model years. (Does not apply to GT500)
The T500-I lower triple tree # is 51410-15010.
The T500-II thru T500J triple tree # is 51410-15110.
The T500M lower & upper triple tree #s are 51410-15110.
The triple tree part # for your T500-I is different than later model #s. But the fork tube spacing is likely the same.
The fork outer tube is the same for all T500s. So I would expect the front fender to be interchangeable for all T500 model years.
The T500 has steel fork outer tubes & the GT500 has cast aluminum(ish) fork outer tubes. So the GT500 fender may be different.
Did the same with my first-year T350 restoration, which has a later-model front fender. Easier to find + they look better.
Slarsonroy
Thank you, excellent information.
karl pa
Country: us
Suzuki 2-Strokes: GT
Post by karl pa »
jabcb wrote: Mon Apr 19, 2021 6:28 am So the GT500 fender may be different.
The GT500 shares the same front fender mounting as the GT550 and I believe the GT750, the holes for bolts are side by side,not up and down.
76 GT185
77 GT250
77 GT380
73 GT550
73 GT750
74 GT750
71 T250 scrambler
75 T500 cafe
