Honda CB 750k5
Other makes and motorcycles of interest.
Monkey man
Suzuki 2-Strokes: T 250 t500 gt 550
Honda CB 750k5
Post by Monkey man »
Hi guys - monkey man here not with a problem on my kettle but this time with my honda 750.
I’m attempting to take off the carbs because of running problems/ lack of use / stale fuel - to examine and clean them but there’s not much room - any tips to do so - the haynes manual just says loosen the throttle cables and clips to the rubbers and pull off but it’s not that simple - do i attempt to remove the air box ? i can’t find a u tube article on this model to show how it’s done
Re: Honda CB 750k5
Remind us again, which bit of the Motherland are you in?
There's a guy in Rotherham who specialises in 70s Hondas - especially the CB750, and 'does' carbs properly.
Rother Classics, and his name's Steve. Mention my name - it'll not get you a discount, but he'll know you're a proper biker.
Otherwise David Silver?
gammakeith
Country: United Kingdom
Suzuki 2-Strokes: 1966 T20
Re: Honda CB 750k5
Post by gammakeith »
I had a K6 for many years that I did close to 80,000 miles on. I do recall that taking the carbs out was not a lot of fun (but then my GT750 wasn't easy either). I didn't remove air box but you should be able to pull the carb bank back towards the box to get them out at the front. It may be the rubbers have just gone too hard so maybe try to source a set of nice flexible ones for when you reassemble?
Good luck!
Keith
1927 Scott 3 Speed Super Squirrel
1948 Scott Flying Squirrel
1951 Cyclemaster
1966 Suzuki T20
1981 Montesa 349
1985 Suzuki RG500
1999 Honda CRM250AR
Definately NO 4 strokes :-)
Monkey man
Re: Honda CB 750k5
cheers guys - i’m up in the cold north east
The fun starts tomorrow night as i have seconded a pal to try and give me a hand - he doesn’t know what he’s letting himself in for 😬
Fingers crossed
Re: Honda CB 750k5
You probably will get useful advise if you join a Honda CB forum & ask there.
Monkey man
Re: Honda CB 750k5
hi guys just an update sorry it’s taken so long - we loosened off the air box behind the carbs and the carbs came out pretty easy - putting them back on was a bit more difficult - we had to split the air box and loosely refit the top half before sliding the carbs back in/on . once they were on we offered up the lower part of the air box and tightened everything back up - all in all it took us about 3 hours including taking float bowls off and cleaning all jets
