1973 GT750 (Time for refresh)
two-stroke-brit
Suzuki 2-Strokes: gt750
refresh
Post by two-stroke-brit »
looking like a thorough going over to me.
mark
1973 SUZUKI GT750K.=SOLD
1982 HONDA CB900F =SOLD
1982 YAMAHA RD350LC.
1985 RZ350N
Zook-e
Smokin'
Post by Zook-e »
tz375 wrote:That's looking good.
Any plans for bodywork upgrades or suspension changes while it's apart?
The only changes on this 73 are maybe braided brake lines, aftermarket shocks, aluminum rims. All else pretty much stock. I would like to go with the European gold color thought. I do also plan to match the ports and and remove all the slag.
Eric,
When I run computer simulations, it clearly shows that a JKL makes more bottom end than an MAB so I tried that early intake timing with later exhaust timing as well as with some pretty radical ports, and it comes back the same. It always props up the powerband below 5k and hurts slightly above 5K.
I can get all the port time are I want on the intake with a slight clean up and widening without dropping the floor or cutting the skirt.
But that's 100% theoretical. I just thought I'd pass that along for what it's worth.
Zook-e
Smokin'
Post by Zook-e »
Couple of more things done over the weekend. Some zinc plating of bolts and the oil tank base mount.
Oil tank cleaned and installed.
Battery box painted with with freshly zinc plated bolts and washers.
Battery box harness plate repainted and awaiting repaired harness. Had some bare wires in the harness that fried my rectifier and battery.
Zook-e
Smokin'
Post by Zook-e »
tz375 wrote:Eric,
'Preciate the that. Just doing a mild cleanup as I really like it stock. But you can sure see where it needs some attention for better flow.
two-stroke-brit
sroket choice
tell me zooke what sprocket combo do you run with,
cheers mark
1985 RZ350N
Zook-e
Smokin'
Post by Zook-e »
Well just me up with DiamondJ and got two swingers to try on the Buff. Hope one of them is what I will like. If so then off to durgam to get some final mods done before it is installed.
